You have redeemed some badges, but now you want to show them off.
To reach this area, you will need to click on the settings icon in the bottom left area and then make sure you're in the "Account" area. This should bring you to your "Badges" section, which will look something like this when you don't have any badges on display at this time:
As explained in this section, all you have to do is click and drag the badges that you want to become visible on servers into the blurred row at the top. Here's an example:
Now, when you're in a server, you should now see your badges alongside your username:
| 💡Tip: If you don't see your badges displaying next to your username, you might need to enable "Use myTS Features" on the server you are visiting. If you have already bookmarked the server, all you have to do is right-click on the server name and click "edit," or if you are currently in the server, right-click on the server name at the top of the screen and select "Edit Bookmark". |
Both of these options should lead you here, where you can toggle this option:
Comments
1 comment
thank u ts
