Open up the TeamSpeak 3 app -> choose "Bookmarks" and add two different servers you want to connect to -> Connect to the server of your choice.
Once you are connected to the first server hit the back button in the upper left of your screen -> tap the "Bookmarks" button.
Now choose the second server and hit "Connect to server". You are now connected to 2 different TeamSpeak 3 servers at once.
In order to switch between these two servers just tap the servername (back button) in the upper left corner of your screen -> tap "Home".
You will be presented with a list that shows the servers you are connected to. Just select one of those servers by tapping on its name and it will become active.
Comments
0 comments
