Once you set your voice mode to "Voice Activation", tap on the little microphone at the bottom while you are on a server. A window with gain control will show up.
Speak a few sentences into your device and hit the "Auto Settings" button. The voice activation feature should now be set so that it only activates once you start talking.
Comments
0 comments
