In the TeamSpeak 3 app, click on 'settings', you will be presented with the configuration dialog where you can set your preferred voice mode.
Click on 'Voice mode' and choose one of the three options: Voice Activated, Push To Talk and Continuous. If you choose to use Voice Activation, make sure to enable "Echo Cancel" in the configuration dialog as well.
Comments
2 comments
Helpful for the most part, but should say 'Options' instead of 'Settings'
Hi my ingame name is AzureDawm
